Salta al contenuto principale
Nokia 8265 Logic Board Replacement
Cosa ti serve
  1. Nokia 8265 Logic Board Replacement, Logic Board: passo 1, immagine 1 di 1
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Nokia 8265 Logic Board Replacement: passo 2, immagine 1 di 1
    • Once the face plate is off, you will have exposed the keypad.
  3. Nokia 8265 Logic Board Replacement: passo 3, immagine 1 di 1
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  4. Nokia 8265 Logic Board Replacement: passo 4, immagine 1 di 1
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  5. Nokia 8265 Logic Board Replacement: passo 5, immagine 1 di 1
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
    • The screen section will be able to be removed after Step 4 is finished.
  6. Nokia 8265 Logic Board Replacement: passo 6, immagine 1 di 1
    • Be careful when removing the Logic Board from the body, lifting it with fingers on both sides to prevent damage of the Logic Board.
    • Separate the Logic Board from the main body of the device.
  7. Nokia 8265 Logic Board Replacement: passo 7, immagine 1 di 1
    • Insert in the replacement Logic Board, setting the Logic Board carefully back into place.
  8. Nokia 8265 Logic Board Replacement: passo 8, immagine 1 di 1
    • Set the screen carefully over the body of the phone, avoiding any sliding on the Logic board
  9. Nokia 8265 Logic Board Replacement: passo 9, immagine 1 di 1
    • Replace screws in the corresponding slots, tightening them till they are not loose.
  10. Nokia 8265 Logic Board Replacement: passo 10, immagine 1 di 1
    • Replace keypad onto the device
  11. Nokia 8265 Logic Board Replacement: passo 11, immagine 1 di 1
    • Lastly, you can place the cover onto the phone. You will know when it is in place if you hear a click after placing it in.
Linea Traguardo
Jack
Membro da: 04/20/12
1 Reputazione
4 Guide realizzate
SUNY Cortland, Team 1-1, Getto Spring 2012 Membro di SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
2 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,168
