Salta al contenuto principale
Nokia 8260 Microphone Replacement
Cosa ti serve
  1. Nokia 8260 Microphone Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the cell phone.
  2. Nokia 8260 Microphone Replacement: passo 2, immagine 1 di 1
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Microphone Replacement: passo 3, immagine 1 di 1
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Microphone Replacement: passo 4, immagine 1 di 1
    • Remove the back cover.
  5. Nokia 8260 Microphone Replacement: passo 5, immagine 1 di 1
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Microphone Replacement: passo 6, immagine 1 di 1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Microphone Replacement, Antenna: passo 7, immagine 1 di 1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Microphone Replacement: passo 8, immagine 1 di 1
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Microphone Replacement: passo 9, immagine 1 di 1
    • Remove the antenna door.
  10. Nokia 8260 Microphone Replacement: passo 10, immagine 1 di 1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  11. Nokia 8260 Microphone Replacement, Circuit Board: passo 11, immagine 1 di 1
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  12. Nokia 8260 Microphone Replacement: passo 12, immagine 1 di 1
    • Remove the back covering.
  13. Nokia 8260 Microphone Replacement: passo 13, immagine 1 di 1
    • Remove the two screws at the top.
  14. Nokia 8260 Microphone Replacement: passo 14, immagine 1 di 1
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
  15. Nokia 8260 Microphone Replacement, Keypad: passo 15, immagine 1 di 1
    • Remove the plastic border lying on the keypad.
  16. Nokia 8260 Microphone Replacement: passo 16, immagine 1 di 1
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
  17. Nokia 8260 Microphone Replacement, Microphone: passo 17, immagine 1 di 1
    • Remove the microphone.
Conclusione
Aaron Jen
Membro da: 04/11/10
1 Reputazione
7 Guide realizzate
Cal Poly, Team 27-94, Amido Spring 2010 Membro di Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,229
