Introduzione
How to remove the LCD.
Parti
Nessuna parte richiesta.
Turn off the cell phone.
  • Turn off the cell phone.
Aggiungi Commento
Press down on the round button on the back cover of the phone.
  • Press down on the round button on the back cover of the phone.
Aggiungi Commento
Slide the back cover down while still pressing the button.
  • Slide the back cover down while still pressing the button.
Aggiungi Commento
Remove the back cover.
  • Remove the back cover.
Aggiungi Commento
Press the end of the battery towards the top of the phone.
  • Press the end of the battery towards the top of the phone.
Aggiungi Commento
Lift the battery outwards while still pressing it upwards till it pops out.
  • Lift the battery outwards while still pressing it upwards till it pops out.
  • You may need to take several attempts to lift out the battery.
Aggiungi Commento
Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
  • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
  • This step may be a bit difficult if you are removing the antenna for the first time.
Aggiungi Commento
Pry open the antenna door by pulling down the top of the spudger
  • Pry open the antenna door by pulling down the top of the spudger
Aggiungi Commento
Remove the antenna door.
  • Remove the antenna door.
Aggiungi Commento
If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
  • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
  • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
  • Try to keep the antenna as flat as possible. Do not bend it.
Aggiungi Commento
Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
  • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
  • The two bottom screws are longer than the upper three.
Aggiungi Commento
Remove the back covering.
  • Remove the back covering.
Aggiungi Commento
Remove the two screws at the top.
  • Remove the two screws at the top.
Aggiungi Commento
Remove the metal plating and the circuit board.
  • Remove the metal plating and the circuit board.
  • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
  • The LCD will be attached to the circuit board.
Aggiungi Commento
Detach the LCD from the logic board at the four metal hinges.
  • Detach the LCD from the logic board at the four metal hinges.
  • There are three pieces to the LCD: the front metal border, the LCD unit, and the plastic backing. Unless you are replacing the LCD, do not separate these three pieces.
Aggiungi Commento
Conclusione
Aaron Jen
Membro da: 11/04/2010
1 Reputazione
14 Guide realizzate
Cal Poly, Team 27-94, Amido Spring 2010 Membro di Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 2,708
