Introduzione
This guide explains how to clean and replace the keypad of your cell phone.
Parti
Nessuna parte richiesta.
Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone. Lift off your cell phone's back cover.
  • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
  • Lift off your cell phone's back cover.
Aggiungi Commento
Use your index finger to first push down and then lift up the battery as shown. Remove the battery from your cell phone.
  • Use your index finger to first push down and then lift up the battery as shown.
  • Remove the battery from your cell phone.
Aggiungi Commento
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Open the front cover of your cell phone with the plastic opening tool or finger nail. Lift the cover upwards, starting from the bottom below the keypad.
  • Open the front cover of your cell phone with the plastic opening tool or finger nail.
  • Lift the cover upwards, starting from the bottom below the keypad.
Aggiungi Commento
Lift the keypad off of the keyboard as it is not attached to the phone anymore. If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
  • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
  • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
  • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Tim Bergmann
Membro da: 18/01/2010
35 Reputazione
8 Guide realizzate
Cal Poly, Team 3-17, Maness Winter 2010 Membro di Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,021
