Introduzione
If you have to replace the logic board than use this installation instruction for the logic board.
Parti
Nessuna parte richiesta.
Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone. Lift off your cell phone's back cover.
  • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
  • Lift off your cell phone's back cover.
Aggiungi Commento
Use your index finger to first push down and then lift up the battery as shown. Remove the battery from your cell phone.
  • Use your index finger to first push down and then lift up the battery as shown.
  • Remove the battery from your cell phone.
Aggiungi Commento
Open the front cover of your cell phone with the plastic opening tool or finger nail. Lift the cover upwards, starting from the bottom below the keypad.
  • Open the front cover of your cell phone with the plastic opening tool or finger nail.
  • Lift the cover upwards, starting from the bottom below the keypad.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Lift the keypad off of the keyboard as it is not attached to the phone anymore. If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
  • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
  • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
  • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
Aggiungi Commento
Remove six Torx 6 screws with the screwdriver.
  • Remove six Torx 6 screws with the screwdriver.
Aggiungi Commento
Remove the frame that holds the keyboard and the display.
  • Remove the frame that holds the keyboard and the display.
Aggiungi Commento
Lift the logic board of out the rear case of the phone.
  • Lift the logic board of out the rear case of the phone.
Aggiungi Commento
This is the logic board of your cell phone. Make sure that you get the right logic board to replace your old one by comparing the serial numbers on it.
  • This is the logic board of your cell phone.
  • Make sure that you get the right logic board to replace your old one by comparing the serial numbers on it.
Aggiungi Commento
Conclusione
Tim Bergmann
Membro da: 18/01/2010
35 Reputazione
8 Guide realizzate
Cal Poly, Team 3-17, Maness Winter 2010 Membro di Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,032
