Introduzione
The back cover of the phone will have to be removed first. No tools are required.
Turn the phone so it is face down (keypad side is down).
  • Turn the phone so it is face down (keypad side is down).
Aggiungi Commento
Press and hold the button located at the bottom of the phone. Slide the back of the phone downwards and away from the main body. Remove the backing and place it to the side.
  • Press and hold the button located at the bottom of the phone.
  • Slide the back of the phone downwards and away from the main body.
  • Remove the backing and place it to the side.
Aggiungi Commento
Locate indentation from which battery can be removed. Place finger in indentation and lift battery up from phone's body. Remove battery from phone's body.
  • Locate indentation from which battery can be removed.
  • Place finger in indentation and lift battery up from phone's body.
  • Remove battery from phone's body.
Aggiungi Commento
Conclusione
To replace the battery, simply put a new battery in the back of the phone, and replace the back cover.
Reid Polstra
Membro da: 22/10/2012
1 Reputazione
7 Guide realizzate
Clemson, Team 15-5, Benson Fall 2012 Membro di Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 915
