Introduzione
Below is a list of instructions on replacing and cleaning a Nokia 6133 keypad.
Parti
Nessuna parte richiesta.
Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone. Lift off back cover.
  • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
  • Lift off back cover.
Aggiungi Commento
Use your index finger to first push down and then lift up the battery as shown. Remove battery from cell phone. Remove battery from cell phone.
  • Use your index finger to first push down and then lift up the battery as shown.
  • Remove battery from cell phone.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Unscrew two T5 torx screws easily visible on the back side of the cell phone Screws: 7.8mm
  • Unscrew two T5 torx screws easily visible on the back side of the cell phone
    • Screws: 7.8mm
  • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
    • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
Aggiungi Commento
Use an iPod opening tool to gently pry open the back case as indicated in the picture. Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary) REPEAT on both sides, and be careful not to stab the circuitry with the tools.
  • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
    • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
  • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
Aggiungi Commento
Gently pull the phone apart and the flexible wire should detach from its connection as shown. If not, lift up on the black tab within the left box in the picture. With the front half of the phone, push the keypad towards the removed portion of the phone.
  • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
    • If not, lift up on the black tab within the left box in the picture.
  • With the front half of the phone, push the keypad towards the removed portion of the phone.
    • To clean, use a damp cloth with water.
Aggiungi Commento
Conclusione
Vincent Benvin
Membro da: 19/04/2010
121 Reputazione
4 Guide realizzate
Cal Poly, Team 23-82, Johann Spring 2010 Membro di Cal Poly, Team 23-82, Johann Spring 2010
CPSU-JOHANN-S10S23G82
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,861
