Salta al contenuto principale
Nokia 6102i motherboard replacement
Cosa ti serve
  1. Nokia 6102i motherboard replacement, Battery: passo 1, immagine 1 di 3 Nokia 6102i motherboard replacement, Battery: passo 1, immagine 2 di 3 Nokia 6102i motherboard replacement, Battery: passo 1, immagine 3 di 3
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
  2. Nokia 6102i motherboard replacement: passo 2, immagine 1 di 1
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
  3. Nokia 6102i motherboard replacement, Logic Board: passo 3, immagine 1 di 2 Nokia 6102i motherboard replacement, Logic Board: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    T6 Torx Screwdriver
    $9.99
    Compra
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
  4. Nokia 6102i motherboard replacement: passo 4, immagine 1 di 2 Nokia 6102i motherboard replacement: passo 4, immagine 2 di 2
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
  5. Nokia 6102i motherboard replacement: passo 5, immagine 1 di 2 Nokia 6102i motherboard replacement: passo 5, immagine 2 di 2
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
  6. Nokia 6102i motherboard replacement: passo 6, immagine 1 di 2 Nokia 6102i motherboard replacement: passo 6, immagine 2 di 2
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 23-78, Johann Spring 2010 Membro di Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,633
