Introduzione
Removing the keyboard from the Nokia 6102i
Parti
Nessuna parte richiesta.
Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover. Note: Images on the right side may be hovered over to reveal larger versions. Note: Images on the right side may be hovered over to reveal larger versions.
  • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
  • Note: Images on the right side may be hovered over to reveal larger versions.
Aggiungi Commento
Lift up the battery from the inside of the phone.
  • Lift up the battery from the inside of the phone.
  • Make sure to lift up from the bottom of the battery as shown.
Aggiungi Commento
Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity. Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
  • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
Aggiungi Commento
Use a plastic opening tool to remove the silver cover over the antenna. The covering may not pop right off.  It may require some prying in different locations around the top covering.
  • Use a plastic opening tool to remove the silver cover over the antenna.
  • The covering may not pop right off. It may require some prying in different locations around the top covering.
Aggiungi Commento
Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver. Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
  • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
Aggiungi Commento
WARNING: Use extreme caution when removing and handling the logic board as it is very fragile. With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
  • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
  • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
  • Disconnect the logic board from the small orange chip.
Aggiungi Commento
Pop out the keyboard from the frame. Once the logic board is removed, the keypad can be easily popped out from the frame with very little force.
  • Pop out the keyboard from the frame.
  • Once the logic board is removed, the keypad can be easily popped out from the frame with very little force.
  • The picture is showing the three layers: the frame, the keyboard, and the logic board.
Aggiungi Commento
Conclusione
Cal Poly, Team 23-78, Johann Spring 2010 Membro di Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,844
