Introduzione
Replacing a damaged screen.
Parti
Nessuna parte richiesta.
Turn off the phone.
  • Turn off the phone.
  • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
  • Position the phone so that the back side is in view.
Aggiungi Commento
Remove the back battery cover. Apply pressure on the cover while simultaneously sliding the cover downward. Apply pressure on the cover while simultaneously sliding the cover downward.
  • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
Aggiungi Commento
Insert the iPod opening tool between the base of the phone and the phone battery. Position the phone so that the battery won't fall out of the phone. The battery lifts out of the phone fast and easily.
  • Insert the iPod opening tool between the base of the phone and the phone battery.
  • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
  • Carefully lift the battery out of the phone.
Aggiungi Commento
Close the phone.
  • Close the phone.
  • Face the front cover forward.
Aggiungi Commento
Locate the 4.5 mm notch at the top of the phone. Place the iPod opening tool into the opening.
  • Locate the 4.5 mm notch at the top of the phone.
  • Place the iPod opening tool into the opening.
  • Slightly prop up the top section by lifting the tool.
Aggiungi Commento
Wedge the iPod opening tool between the top cover and the phone. Gently lift the top cover away from the phone using the iPod opening tool. This unlatches each hook that connects the top cover to the phone.
  • Wedge the iPod opening tool between the top cover and the phone.
  • Gently lift the top cover away from the phone using the iPod opening tool.
    • This unlatches each hook that connects the top cover to the phone.
  • Repeat for both the left and the right sides of the phone.
  • Place the top cover aside once the top cover is completely disconnected from the phone.
Aggiungi Commento
Locate the four screws on the phone. The top right screw is located under the black connector piece. To remove the connector piece gently lift it off of its connector.
  • Locate the four screws on the phone.
    • The top right screw is located under the black connector piece.
    • To remove the connector piece gently lift it off of its connector.
  • Take the T6 driver and remove the screws.
Aggiungi Commento
Carefully lift up the motherboard.
  • Carefully lift up the motherboard.
Aggiungi Commento
Find the orange slip on the motherboard. Peel back the orange slip to expose the screen.
  • Find the orange slip on the motherboard.
  • Peel back the orange slip to expose the screen.
Aggiungi Commento
Place the ipod opening tool under the screen. Remove the damaged screen with the ipod opening tool. Remove the damaged screen with the ipod opening tool.
  • Place the ipod opening tool under the screen.
  • Remove the damaged screen with the ipod opening tool.
Aggiungi Commento
Conclusione
Caitlin Rahm
Membro da: 15/04/2010
78 Reputazione
7 Guide realizzate
Cal Poly, Team 26-30, Regan Spring 2010 Membro di Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Membri
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,218
