Introduzione
Replacing a broken headphone port.
Turn off the phone.
  • Turn off the phone.
  • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
  • Position the phone so that the back side is in view.
Aggiungi Commento
Remove the back battery cover. Apply pressure on the cover while simultaneously sliding the cover downward. Apply pressure on the cover while simultaneously sliding the cover downward.
  • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
Aggiungi Commento
Insert the iPod opening tool between the base of the phone and the phone battery. Position the phone so that the battery won't fall out of the phone. The battery lifts out of the phone fast and easily.
  • Insert the iPod opening tool between the base of the phone and the phone battery.
  • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
  • Carefully lift the battery out of the phone.
Aggiungi Commento
Turn the phone so that the back of the phone is facing forward.
  • Turn the phone so that the back of the phone is facing forward.
  • The picture to the left shows the location of the plastic tabs that attach to the upper cover of the phone.
    • In this picture, the upper cover has already been removed.
Aggiungi Commento
Place the iPod opening tool under the tabs near the top of the phone. Slide the iPod Opening Tool upwards.
  • Place the iPod opening tool under the tabs near the top of the phone.
  • Slide the iPod Opening Tool upwards.
    • This will pop the tabs and release the upper part of the phone.
  • Repeat for the left and the right sides.
Aggiungi Commento
Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture). Lift the iPod opening tool to pop open the clips.
  • Place the iPod opening tool at the top area of the bottom section of the phone (indicated in picture).
  • Lift the iPod opening tool to pop open the clips.
    • This will release the upper back cover of the phone.
Aggiungi Commento
Push upward on the top back cover using two thumbs. This will remove the top back cover from the phone. This will remove the top back cover from the phone.
  • Push upward on the top back cover using two thumbs.
    • This will remove the top back cover from the phone.
Aggiungi Commento
Locate the four screws. Remove the screws using a T6 Torx screwdriver.
  • Locate the four screws.
  • Remove the screws using a T6 Torx screwdriver.
Aggiungi Commento
Turn the phone over. Gently pull apart the phone.
  • Turn the phone over.
  • Gently pull apart the phone.
    • Start at the bottom of the phone and pull outward.
    • There are plastic catches on the middle of each side. These should pop free as you pull.
    • Be careful, the phone will separate into two sections.
Aggiungi Commento
The phone should now be in two different sections. 1) The logic board and the back cover
  • The phone should now be in two different sections.
    • 1) The logic board and the back cover
    • 2) The keypad and the rest of the phone
Aggiungi Commento
Turn the phone so that the back section is facing forward.
  • Turn the phone so that the back section is facing forward.
  • Locate the black headphone port at the bottom of the phone.
Aggiungi Commento
Grip the headphone port with the tweezers.
  • Grip the headphone port with the tweezers.
  • Lift the headphone port out of the phone using the tweezers.
Aggiungi Commento
The headphone port should be fully detached from the phone. The headphone port should be fully detached from the phone.
  • The headphone port should be fully detached from the phone.
Aggiungi Commento
Conclusione
Caitlin Rahm
Membro da: 15/04/2010
78 Reputazione
7 Guide realizzate
Cal Poly, Team 26-30, Regan Spring 2010 Membro di Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Membri
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,296
