Salta al contenuto principale
Nokia 6086 Battery Replacement
Cosa ti serve
  1. Nokia 6086 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Battery Replacement: passo 2, immagine 1 di 3 Nokia 6086 Battery Replacement: passo 2, immagine 2 di 3 Nokia 6086 Battery Replacement: passo 2, immagine 3 di 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Battery Replacement: passo 3, immagine 1 di 3 Nokia 6086 Battery Replacement: passo 3, immagine 2 di 3 Nokia 6086 Battery Replacement: passo 3, immagine 3 di 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
Conclusione
Andrea
Membro da: 04/15/10
70 Reputazione
5 Guide realizzate
Cal Poly, Team 26-30, Regan Spring 2010 Membro di Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,833
