Introduzione
Replacing the phones microphone
Parti
Nessuna parte richiesta.
Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  • Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Aggiungi Commento
Use your fingernail and gently pull the the bottom of the battery up. Lift out battery and remove. Lift out battery and remove.
  • Use your fingernail and gently pull the the bottom of the battery up.
  • Lift out battery and remove.
Aggiungi Commento
Use your fingernail to lift the metal cage up. Remove SIM card. Remove SIM card.
  • Use your fingernail to lift the metal cage up.
  • Remove SIM card.
Aggiungi Commento
Close the metal cage.
  • Close the metal cage.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen. Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
  • Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
Aggiungi Commento
After removing the top cover, turn the phone over so the screen is facing upwards. After removing the top cover, turn the phone over so the screen is facing upwards.
  • After removing the top cover, turn the phone over so the screen is facing upwards.
Aggiungi Commento
Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows. Lift the front off the phone by pulling above the arrows.
  • Lift the front off the phone by pulling above the arrows.
Aggiungi Commento
Remove the six screws with a T-6 Torx screwdriver. Remove the six screws with a T-6 Torx screwdriver. Remove the six screws with a T-6 Torx screwdriver.
  • Remove the six screws with a T-6 Torx screwdriver.
Aggiungi Commento
Lift the logic board and screen from the top. Be careful of loose parts. Be careful of loose parts.
  • Lift the logic board and screen from the top.
  • Be careful of loose parts.
Aggiungi Commento
Use tweezers to aid in the removal of the microphone. Use tweezers to aid in the removal of the microphone. Use tweezers to aid in the removal of the microphone.
  • Use tweezers to aid in the removal of the microphone.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 23-63, Johann Spring 2010 Membro di Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Membri
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,774
