Introduzione
Guide to install the Nokia 6030 battery.
Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone. Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  • Press the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
Aggiungi Commento
Use your fingernail and gently pull the the bottom of the battery up. Lift out battery and remove. Lift out battery and remove.
  • Use your fingernail and gently pull the the bottom of the battery up.
  • Lift out battery and remove.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 23-63, Johann Spring 2010 Membro di Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Membri
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,079
