Introduzione
Guide to replacing keypad of Nokia 3360
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
  • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
  • Lift the back plate off the phone.
Aggiungi Commento
To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
Aggiungi Commento
Lift the battery out of the phone. Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  • Lift the battery out of the phone.
  • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
Aggiungi Commento
Use finger nails of your thumbs to gently pull apart the face plate. While the face plate is pulled apart, use index fingers to pull inner case towards you.
  • Use finger nails of your thumbs to gently pull apart the face plate.
  • While the face plate is pulled apart, use index fingers to pull inner case towards you.
  • Separate faceplate and inner case.
Aggiungi Commento
Gently peel up the edge of plastic keypad from the inside of the faceplate to remove.
  • Gently peel up the edge of plastic keypad from the inside of the faceplate to remove.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Travis Malmgren
Membro da: 26/01/2010
45 Reputazione
4 Guide realizzate
Cal Poly, Team 8-39, Regan Winter 2010 Membro di Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 3,552
