Introduzione
Changing the Battery is easy -- no tools required.
Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
  • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
  • Lift the back plate off the phone.
Aggiungi Commento
To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
Aggiungi Commento
Lift the battery out of the phone. Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  • Lift the battery out of the phone.
  • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
Aggiungi Commento
Conclusione
Cal Poly, Team 8-39, Regan Winter 2010 Membro di Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,002
