Salta al contenuto principale
Nokia 3300B Motherboard Replacement
Cosa ti serve
  1. Nokia 3300B Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Nokia 3300B Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Motherboard Replacement: passo 2, immagine 1 di 2 Nokia 3300B Motherboard Replacement: passo 2, immagine 2 di 2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Motherboard Replacement, Keyboard: passo 3, immagine 1 di 2 Nokia 3300B Motherboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Motherboard Replacement: passo 4, immagine 1 di 1
    • With the screen still facing you, lift and remove the blue faceplate.
  5. Nokia 3300B Motherboard Replacement: passo 5, immagine 1 di 1
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
  6. Nokia 3300B Motherboard Replacement, Motherboard: passo 6, immagine 1 di 2 Nokia 3300B Motherboard Replacement, Motherboard: passo 6, immagine 2 di 2
    • Remove the six Torx T6 screws from the phone's front case.
  7. Nokia 3300B Motherboard Replacement: passo 7, immagine 1 di 1
    • Pull up on the front case containing the screen to separate it from the rest of the phone.
    • Gently lift the main board out of the back case.
Conclusione
Altre 3 persone hanno completato questa guida.
Jose Quezada
Membro da: 04/13/10
50 Reputazione
1 Guida realizzata
Cal Poly, Team 18-65, Johann Spring 2010 Membro di Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,888
