Introduzione
Use this guide to replace the keyboard of the Nokia 3300B.
Strumenti
Nessun attrezzo richiesto.
Parti
Nessuna parte richiesta.
Flip the Nokia 3300B over with the back-side facing towards you. Gently press the button on the back of the battery cover to release the cover and slide up.
  • Flip the Nokia 3300B over with the back-side facing towards you.
  • Gently press the button on the back of the battery cover to release the cover and slide up.
Aggiungi Commento
Lift the battery out of the back of the phone. It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  • Lift the battery out of the back of the phone.
  • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Gently push the blue tabs on the top of the phone out of their slots.
  • Gently push the blue tabs on the top of the phone out of their slots.
  • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
  • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
Aggiungi Commento
With the screen still facing you, lift and remove the blue faceplate.
  • With the screen still facing you, lift and remove the blue faceplate.
Aggiungi Commento
Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
  • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
  • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
  • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Chris Colwell
Membro da: 13/04/2010
77 Reputazione
3 Guide realizzate
Cal Poly, Team 18-65, Johann Spring 2010 Membro di Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,402
