Introduzione
A guide that describes how to replace the battery of a Nokia 3300B.
Flip the Nokia 3300B over with the back-side facing towards you. Gently press the button on the back of the battery cover to release the cover and slide up.
  • Flip the Nokia 3300B over with the back-side facing towards you.
  • Gently press the button on the back of the battery cover to release the cover and slide up.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Lift the battery out of the back of the phone. It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  • Lift the battery out of the back of the phone.
  • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
George
Membro da: 13/04/2010
91 Reputazione
4 Guide realizzate
Cal Poly, Team 18-65, Johann Spring 2010 Membro di Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,363
