Introduzione
The SIM card is used to store information and it is well hidden under the battery. It is very easy to open once you know where it is.
Parti
Nessuna parte richiesta.
Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
  • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Aggiungi Commento
Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
  • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Once the battery is removed, the SIM card compartment will be exposed.  Pry the compartment open as seen in the figure.  This can be done using your fingernail or a prying mechanism.
  • Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
Aggiungi Commento
Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
  • Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Justin Emerson
Membro da: 11/03/2013
136 Reputazione
4 Guide realizzate
Clemson, Team 13-2, Benson Spring 2013 Membro di Clemson, Team 13-2, Benson Spring 2013
CLEM-BENSON-S13S13G2
3 Membri
14 Guide realizzate
Thanks , appreciated.
Ian McCully - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 46
Tutti i Tempi: 3,100
