Introduzione
If your buttons are sticky, the numbers are worn off, or the keypad is malfunctioning, simply clean or replace it.
Parti
Nessuna parte richiesta.
Be sure cell phone is off before you begin to disassemble the phone. Press the button on the bottom of the back of the cell phone. Slide rear panel down and remove  it.
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Aggiungi Commento
Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out.
  • Using your fingernail, pry the back of the battery upwards and pull out.
Aggiungi Commento
Insert the plastic opening tool under the faceplate. Separate the faceplate from main body by twisting the prying tool with some force. The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Aggiungi Commento
With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove.
  • With the faceplate removed, simply peel off rubber key pad and remove.
Aggiungi Commento
Conclusione
Chad
Membro da: 29/10/2010
10 Reputazione
10 Guide realizzate
Cal Poly, Team 20-8, Maness Fall 2010 Membro di Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Membri
28 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 916
