Salta al contenuto principale
Nokia 1100b RH-36 Screen Replacement
Cosa ti serve
  1. Nokia 1100b RH-36 Screen Replacement, Battery Cover: passo 1, immagine 1 di 2 Nokia 1100b RH-36 Screen Replacement, Battery Cover: passo 1, immagine 2 di 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Screen Replacement, Battery: passo 2, immagine 1 di 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Screen Replacement, Removing Nokia 1100b RH-36 Front Cover: passo 3, immagine 1 di 2 Nokia 1100b RH-36 Screen Replacement, Removing Nokia 1100b RH-36 Front Cover: passo 3, immagine 2 di 2
    • Firmly grip the back of the casing.
    • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
    • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
  4. Nokia 1100b RH-36 Screen Replacement, Inner Casing: passo 4, immagine 1 di 2 Nokia 1100b RH-36 Screen Replacement, Inner Casing: passo 4, immagine 2 di 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  5. Nokia 1100b RH-36 Screen Replacement, Screen: passo 5, immagine 1 di 2 Nokia 1100b RH-36 Screen Replacement, Screen: passo 5, immagine 2 di 2
    • Flip over the metal frame you just removed.
    • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
    • Remove the screen bearing plastic frame.
Conclusione
Altre 2 persone hanno completato questa guida.
JSwan
Membro da: 04/12/13
751 Reputazione
6 Guide realizzate
Cal Poly, Team 10-43, Amido Spring 2013 Membro di Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,805
