Introduzione
If you are having trouble with the USB port or solar panel, then these steps should be used to replace it altogether.
Turn over the device so that the back of the device is facing up.
  • Turn over the device so that the back of the device is facing up.
Aggiungi Commento
Insert the first plastic opening tool along the side to pry open the case. Sliding the plastic opening tool, while inserted, along the seam may help the removal process. Use a second plastic opening tool to help separate the remaining seams.
  • Insert the first plastic opening tool along the side to pry open the case.
  • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
  • Use a second plastic opening tool to help separate the remaining seams.
Aggiungi Commento
There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed. Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
  • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
Aggiungi Commento
Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board. Remove the solar panel and circuit board from the front case.
  • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
  • Remove the solar panel and circuit board from the front case.
Aggiungi Commento
Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly. Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
  • Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
Aggiungi Commento
Conclusione
Nicholas Orr
Membro da: 20/01/2015
216 Reputazione
2 Guide realizzate
USF Tampa, Team 9-3, Blackwell Winter 2015 Membro di USF Tampa, Team 9-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G3
3 Membri
3 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 108
