Introduzione
If the suction cup no longer sticks to surfaces or if the plastic has split, you will need to replace the suction cup with a new one.
Press down firmly to remove the battery cover and display battery. Then remove the battery. Then remove the battery.
  • Press down firmly to remove the battery cover and display battery.
  • Then remove the battery.
Aggiungi Commento
Remove the 7mm Phillips #1 screw. Remove the 7mm Phillips #1 screw.
  • Remove the 7mm Phillips #1 screw.
Aggiungi Commento
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device. Unlatch the clips on the inside and pull device apart.
  • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
  • Unlatch the clips on the inside and pull device apart.
  • Some clips will break when forced open.
Aggiungi Commento
Using tweezers, push the edges of the back end of the suction cup inward. Using tweezers, push the edges of the back end of the suction cup inward.
  • Using tweezers, push the edges of the back end of the suction cup inward.
Aggiungi Commento
Flip the cover over and remove the suction cup by pulling at an angle. Be careful not to tear the plastic housing.
  • Flip the cover over and remove the suction cup by pulling at an angle.
  • Be careful not to tear the plastic housing.
  • During reassembly, make sure to press down uniformly on the suction cup for an even fit.
Aggiungi Commento
Conclusione
Daniel Bumiller
Membro da: 20/01/2015
201 Reputazione
2 Guide realizzate
USF Tampa, Team 19-2, Blackwell Winter 2015 Membro di USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 59
