Parti
Nessuna parte richiesta.
Flip the Wii Remote over so the battery cover faces you. Push up on the bottom tab.
  • Flip the Wii Remote over so the battery cover faces you.
  • Push up on the bottom tab.
  • Remove the battery cover.
Aggiungi Commento
Remove the first battery by pressing down on the positive end and pulling the battery out.
  • Remove the first battery by pressing down on the positive end and pulling the battery out.
  • Remove the second battery by pushing up on the positive end and pulling the battery out.
Aggiungi Commento
Using a Tri-wing Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
  • Using a Tri-wing Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
  • Repeat with the two bottom screws.
Aggiungi Commento
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller. These tabs are breakable. However, if the tabs are broken the controller will still function.
  • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
  • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
Aggiungi Commento
Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you. Grip the outward edge of the screen with your fingers. Gently, pull the screen straight outward from its housing. The screen will slide directly out.
  • Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
  • Grip the outward edge of the screen with your fingers.
  • Gently, pull the screen straight outward from its housing. The screen will slide directly out.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Emily
Membro da: 14/04/2013
646 Reputazione
6 Guide realizzate
Cal Poly, Team 3-44, Amido Spring 2013 Membro di Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 119
Tutti i Tempi: 7,137
