Salta al contenuto principale
Nintendo Wii Remote Motherboard Replacement
Cosa ti serve
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: passo 1, immagine 1 di 2 Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: passo 1, immagine 2 di 2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Motherboard Replacement: passo 3, immagine 1 di 1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Motherboard Replacement: passo 4, immagine 1 di 2 Nintendo Wii Remote Motherboard Replacement: passo 4, immagine 2 di 2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: passo 5, immagine 1 di 2 Nintendo Wii Remote Motherboard Replacement, Motherboard: passo 5, immagine 2 di 2
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  6. Nintendo Wii Remote Motherboard Replacement: passo 6, immagine 1 di 2 Nintendo Wii Remote Motherboard Replacement: passo 6, immagine 2 di 2
    • Grasp the edges of the motherboard and pull it straight away from the case.
Conclusione
Altre 26 persone hanno completato questa guida.
Emily
Membro da: 04/14/13
1.494 Reputazione
6 Guide realizzate
Cal Poly, Team 3-44, Amido Spring 2013 Membro di Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Membri
26 Guide realizzate
7 Commenti
Where do you find a motherboard and how much do they typically cost?
Jeff - Replica
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Replica
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Replica
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 86
Ultimi 30 Giorni: 293
Tutti i Tempi: 31,157
