Introduzione
Installing a Wii Remote motherboard requires the removal of the front cover plate and allows access to the B button.
Parti
Nessuna parte richiesta.
Flip the Wii Remote over so the battery cover faces you. Push up on the bottom tab.
  • Flip the Wii Remote over so the battery cover faces you.
  • Push up on the bottom tab.
  • Remove the battery cover.
Aggiungi Commento
Remove the first battery by pressing down on the positive end and pulling the battery out.
  • Remove the first battery by pressing down on the positive end and pulling the battery out.
  • Remove the second battery by pushing up on the positive end and pulling the battery out.
Aggiungi Commento
Using a Tri-wing Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
  • Using a Tri-wing Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
  • Repeat with the two bottom screws.
Aggiungi Commento
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller. These tabs are breakable. However, if the tabs are broken the controller will still function.
  • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
  • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
Aggiungi Commento
Using the connector port, gently lift the motherboard about 2 cm from the base. Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
  • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
Aggiungi Commento
Grasp the edges of the motherboard and pull it straight away from the case. Grasp the edges of the motherboard and pull it straight away from the case.
  • Grasp the edges of the motherboard and pull it straight away from the case.
Aggiungi Commento
Conclusione
Altre 13 persone hanno completato questa guida.
Emily
Membro da: 14/04/2013
646 Reputazione
6 Guide realizzate
Cal Poly, Team 3-44, Amido Spring 2013 Membro di Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
4 Membri
6 Guide realizzate
Where do you find a motherboard and how much do they typically cost?
Jeff - Replica
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Replica
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign -
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Replica
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 41
Ultimi 30 Giorni: 177
Tutti i Tempi: 12,608
