Introduzione
The B button can malfunction or get misaligned due to improper or over use. Installing the B button requires disassembly of the entire device. This means removing the front cover plate, and the motherboard.
Cosa ti serve
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
Using the connector port, gently lift the motherboard about 2 cm from the base.
Locate the black sensor screen found at the bottom end of the Wii remote.
Grip the free edge of the black sensor screen and gently pull it down to remove from the Wii control.
