Salta al contenuto principale
Nintendo WaveBird Wireless Controller C-Stick Replacement
Cosa ti serve
  1. Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: passo 1, immagine 1 di 2 Nintendo WaveBird Wireless Controller C-Stick Replacement, Batteries: passo 1, immagine 2 di 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller C-Stick Replacement: passo 2, immagine 1 di 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: passo 3, immagine 1 di 2 Nintendo WaveBird Wireless Controller C-Stick Replacement, Front Panel: passo 3, immagine 2 di 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller C-Stick Replacement: passo 4, immagine 1 di 2 Nintendo WaveBird Wireless Controller C-Stick Replacement: passo 4, immagine 2 di 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: passo 5, immagine 1 di 3 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: passo 5, immagine 2 di 3 Nintendo WaveBird Wireless Controller C-Stick Replacement, Buttons: passo 5, immagine 3 di 3
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: passo 6, immagine 1 di 2 Nintendo WaveBird Wireless Controller C-Stick Replacement, C-Stick: passo 6, immagine 2 di 2
    • Potential for device damage: Rough handling of the C-stick could cause the daughterboard to break off of the motherboard.
    • Grab the base of the yellow C-Stick cover with one hand and gently hold down the bottom piece of the motherboard with the spudger.
    • Pull off the yellow C-Stick cover.
    • During reassembly, make sure the slots inside the C-Stick cover line up with the motherboard so it can fit back together.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 10-40, Amido Spring 2013 Membro di Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membri
37 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,319
