Introduzione
This guide will teach you how to replace defective buttons. You may need to clean under the buttons if you have sticky buttons.
Parti
Nessuna parte richiesta.
Pull down on the battery cover release lever and pull back to remove the cover. Pull down on the battery cover release lever and pull back to remove the cover.
  • Pull down on the battery cover release lever and pull back to remove the cover.
Aggiungi Commento
Take out each battery then put the covering back on.
  • Take out each battery then put the covering back on.
Aggiungi Commento
Remove the eight 9-mm Tri-Wing screws on the back panel with the Tri-wing Y1 screwdriver. During reassembly, firmly hold the panels of the controller together while replacing screws so the panels don't separate.
  • Remove the eight 9-mm Tri-Wing screws on the back panel with the Tri-wing Y1 screwdriver.
  • During reassembly, firmly hold the panels of the controller together while replacing screws so the panels don't separate.
Aggiungi Commento
After each screws has been removed carefully turn over the controller, and place on a flat surface. Slowly separate the top panel from the bottom panel.
  • After each screws has been removed carefully turn over the controller, and place on a flat surface.
  • Slowly separate the top panel from the bottom panel.
  • The buttons are loose and may fall off of the motherboard.
  • Once seperarted set aside the top panel.
  • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
Aggiungi Commento
Use tweezers to remove the buttons. It may be easier to remove the A button off of the pad by lifting it with your fingers. During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  • Use tweezers to remove the buttons.
  • It may be easier to remove the A button off of the pad by lifting it with your fingers.
  • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Douglas
Membro da: 15/04/2013
31 Reputazione
1 Guida realizzata
Cal Poly, Team 10-40, Amido Spring 2013 Membro di Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Membri
15 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,489
