Salta al contenuto principale
Nintendo GameCube Controller Z Button Replacement
Cosa ti serve
  1. Nintendo GameCube Controller Z Button Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Z Button Replacement: passo 2, immagine 1 di 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Z Button Replacement, Z Button: passo 3, immagine 1 di 2 Nintendo GameCube Controller Z Button Replacement, Z Button: passo 3, immagine 2 di 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
Conclusione
Altre 7 persone hanno completato questa guida.
Sean Michel
Membro da: 01/14/13
2.496 Reputazione
8 Guide realizzate
Cal Poly, Team 19-44, Regan Winter 2013 Membro di Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Membri
26 Guide realizzate
6 Commenti
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
Augustine Park - Replica
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
Justin Sebastian - Replica
My bad no pic it's a pelican wireless controller
Justin Sebastian -
How do you change the spring? I have replacement z buttons just no spring for them…
Gaf Epar - Replica
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Kevin Alaniz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 101
Tutti i Tempi: 18,855
