Introduzione
In this step we will be removing the bottom panel from the rest of the controller. This is necessary in order to access the inside components of the controller.
WARNING: Use caution when removing the bottom grip panel. Many of the buttons and components are held only loosely by the front panel and can fall out. Be sure to set screws aside carefully.
Parti
Nessuna parte richiesta.
Place the controller (buttons down) on a solid surface.
  • Place the controller (buttons down) on a solid surface.
  • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Gently lift the back panel up, separating it from the front panel.
  • Gently lift the back panel up, separating it from the front panel.
  • Some of the buttons may fall out if they are knocked around.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 19-44, Regan Winter 2013 Membro di Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 53
Tutti i Tempi: 5,659
