Introduzione
For clarification, the trackpads and the directional pad are not the same. This guide is for replacing the rubber pads below the buttons, not the buttons themselves.
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
  • Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
Aggiungi Commento
Lift the battery cover up and remove it from the device.
  • Lift the battery cover up and remove it from the device.
  • The screw will remain attached to the battery cover because of Nintendo's design.
Aggiungi Commento
Use your fingers or a plastic opening tool to remove the battery from the device.
  • Use your fingers or a plastic opening tool to remove the battery from the device.
Aggiungi Commento
Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include: Four #00 6.45mm tri-wing screws that are located at the corners of the device.
  • Using the tri-wing screwdriver, unscrew the screws holding the back cover to the device. The six screws that need to be removed include:
    • Four #00 6.45mm tri-wing screws that are located at the corners of the device.
    • Two #00 4.6mm tri-wing screws that are located at the top-center and bottom-center of the device.
Aggiungi Commento
Lift the back cover off of the device.
  • Lift the back cover off of the device.
Aggiungi Commento
Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
Aggiungi Commento
Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
  • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
  • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
Aggiungi Commento
Using your fingers, gently lift and remove the trackpads covering the following: 'A' and 'B' buttons Directional Control Button Pad
  • Using your fingers, gently lift and remove the trackpads covering the following:
    • 'A' and 'B' buttons
    • Directional Control Button Pad
    • 'Start' and 'Select' buttons
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
DJ Pantone
Membro da: 11/01/2013
1.012 Reputazione
10 Guide realizzate
Cal Poly, Team 17-22, Forte Winter 2013 Membro di Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Membri
16 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 57
Tutti i Tempi: 4,547
