Salta al contenuto principale
Nintendo Game Boy Advance SP Power Switch Cover Replacement
Cosa ti serve
  1. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Power Switch Cover Replacement: passo 2, immagine 1 di 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Power Switch Cover Replacement: passo 3, immagine 1 di 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: passo 4, immagine 1 di 2 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Back Cover: passo 4, immagine 2 di 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Power Switch Cover Replacement: passo 5, immagine 1 di 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: passo 6, immagine 1 di 2 Nintendo Game Boy Advance SP Power Switch Cover Replacement, Power Switch Cover: passo 6, immagine 2 di 2
    • Lift the power switch cover away from the left side of the device using your fingers or tweezers.
Conclusione
Altre 17 persone hanno completato questa guida.
DJ Pantone
Membro da: 01/11/13
1.924 Reputazione
5 Guide realizzate
Cal Poly, Team 17-22, Forte Winter 2013 Membro di Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Membri
39 Guide realizzate
Un commento
This doesn't explain anything about how to replace the switch
Michael - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 159
Tutti i Tempi: 20,015
