Introduzione
The battery is a rectangular unit with electrical information printed on one side. It is located on the back of the Game Boy Advance SP.
Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
  • Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
Aggiungi Commento
Lift the battery cover up and remove it from the device.
  • Lift the battery cover up and remove it from the device.
  • The screw will remain attached to the battery cover because of Nintendo's design.
Aggiungi Commento
Use your fingers or a plastic opening tool to remove the battery from the device.
  • Use your fingers or a plastic opening tool to remove the battery from the device.
Aggiungi Commento
Conclusione
For reassembly, follow the instructions in reverse order.
Altre 15 persone hanno completato questa guida.
Cal Poly, Team 17-22, Forte Winter 2013 Membro di Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Membri
16 Guide realizzate
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - Replica
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 73
Ultimi 30 Giorni: 370
Tutti i Tempi: 16,854
