Introduzione
Turn up the stereo sound on the DSi XL by replacing the volume control switch.
Remove the two Phillips screws securing the battery cover to the back of the handheld console. Lift the battery cover off the back of the DSi XL.
  • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
  • Lift the battery cover off the back of the DSi XL.
Aggiungi Commento
Lift the battery from the DSi XL.
  • Lift the battery from the DSi XL.
Aggiungi Commento
Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Aggiungi Commento
Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
  • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Turn the DSi XL over, and open the display. Insert a spudger between the upper and lower case at the bottom left corner of the DSi. Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  • Turn the DSi XL over, and open the display.
  • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
  • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
Aggiungi Commento
Close the display and turn the DSi XL over. Lift the lower case from the front edge.
  • Close the display and turn the DSi XL over.
  • Lift the lower case from the front edge.
  • Rotate the lower case away from the DSi.
  • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
Aggiungi Commento
Using a spudger, pry the SD card/right shoulder button connector off its socket. Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  • Using a spudger, pry the SD card/right shoulder button connector off its socket.
  • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
Aggiungi Commento
Remove the two gold 4.0 mm Phillips screws securing the left shoulder button assembly to the lower case. Lift the left shoulder button assembly from the lower case. The components of the left shoulder button assembly:
  • Remove the two gold 4.0 mm Phillips screws securing the left shoulder button assembly to the lower case.
  • Lift the left shoulder button assembly from the lower case.
  • The components of the left shoulder button assembly:
    • Left shoulder button
    • Shoulder button spring
    • Retaining pin
    • Left shoulder button support panel
Aggiungi Commento
On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
  • On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
  • The latch will only move about 1 mm.
Aggiungi Commento
Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment. Using the flat of a spudger, pry the volume control switch straight up out of the lower case. Remove the volume control switch from the DSi XL.
  • Using the flat end of a spudger, remove the adhesive securing the volume control switch ribbon cable to the back of the battery compartment.
  • Using the flat of a spudger, pry the volume control switch straight up out of the lower case.
  • Remove the volume control switch from the DSi XL.
Aggiungi Commento
Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
  • Using the flat end of a spudger, remove the volume control buttons from the metal backing bracket.
  • The bracket is attached by a strong adhesive. Work slowly and carefully, being sure to not damage the ribbon cable.
  • Volume control switch remains.
Aggiungi Commento
Conclusione
Brett Hartt
Membro da: 12/04/2010
105.586 Reputazione
323 Guide realizzate
iFixit Membro di iFixit
Community
114 Membri
5.916 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,984
