Introduzione
Use this guide to replace a faulty microphone in your DSi XL.
Remove the two Phillips screws securing the battery cover to the back of the handheld console. Lift the battery cover off the back of the DSi XL.
  • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
  • Lift the battery cover off the back of the DSi XL.
Aggiungi Commento
Lift the battery from the DSi XL.
  • Lift the battery from the DSi XL.
Aggiungi Commento
Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin. Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Aggiungi Commento
Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
  • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
Aggiungi Commento
Turn the DSi XL over, and open the display. Insert a spudger between the upper and lower case at the bottom left corner of the DSi. Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  • Turn the DSi XL over, and open the display.
  • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
  • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
Aggiungi Commento
Close the display and turn the DSi XL over. Lift the lower case from the front edge.
  • Close the display and turn the DSi XL over.
  • Lift the lower case from the front edge.
  • Rotate the lower case away from the DSi.
  • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
Aggiungi Commento
Using a spudger, pry the SD card/right shoulder button connector off its socket. Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  • Using a spudger, pry the SD card/right shoulder button connector off its socket.
  • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
Aggiungi Commento
Lift the Wi-Fi board up off its socket on the motherboard. Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
  • Lift the Wi-Fi board up off its socket on the motherboard.
  • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
Aggiungi Commento
Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
  • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
Aggiungi Commento
Use a spudger to pry the microphone cable off the motherboard.
  • Use a spudger to pry the microphone cable off the motherboard.
  • Pry from underneath the cable.
Note that the WiFi board has already been removed here! Including this extra step would be convenient here '-)
Sjoerd Hulshof - Replica
Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector. Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
  • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
Aggiungi Commento
Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector. With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
  • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
Aggiungi Commento
Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector. With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
  • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
Aggiungi Commento
Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector. With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
  • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
-This is where you can replace the charger port. i may change this comment later from May 21-June 5
Artemy Matveev - Replica
Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable. With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
  • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
Aggiungi Commento
Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
The battery connectors (socket) on the mother board are extremely fragile, so care should be taken to avoid breaking them.
Other than this, the instructions given are precise and straighforward. I do agree with the other comments about step 20.
Paulette Williams - Replica
Remove the screws securing the motherboard to the upper case:
  • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
the battery connector was (for me) extremely hard to remove. I broke the socket completely off the board hand had to hard solder it directly back.
Rohan Grant-Dawes - Replica
On Step 17, I only had the 3 black Philips screws on the left to remove.
bfmackin - Replica
Deroute the microphone and antenna cables through the slot in the motherboard.
  • Deroute the microphone and antenna cables through the slot in the motherboard.
Aggiungi Commento
Rotate the motherboard off the lower case. The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  • Rotate the motherboard off the lower case.
  • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
Aggiungi Commento
Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector. With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
  • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
  • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
  • The motherboard is now free from the upper case.
This step is unnecessary. The ribbon is a total pain in the butt to get back in, and if you dont get it PERFECT, the DS will not even fire back up. Unless it is absolutely necessary to remove it... DON'T !!! ( Personal experience, Everything else was SPOT ON) THANK YOU FOR THE HELP, saved me a lot of $$$
Jerod Cook - Replica
Completed, worked perfectly! I agree with the comment about step 20, completely unnecessary.
ian - Replica
Fantastic! Fixed my daughter's irreplaceable DSi XL - you should see her smiles!! Not sure about step 20 I did this before reading the comments (guess there's a message there). Thanks so much whoever wrote this - you're a legend and you've made a child very happy (and a dad too thereby).
lb9 - Replica
I put mine back together for my daughter with the new bottom screen, but it won't power on. It tries but won't I'm assuming that this ribbon is the cause.
bigdrum1998 - Replica
The instructions are perfect though! Great thing to have these instructions it's a tremendous help! :-)
YHWH is the god of all knowledge. Put a piece of transparent tape on the ribbon cable to give more leverage to pull the cable up to slide it into the slot. Also turn the motherboard slightly so that you can get it closer to the cable.
Deanna Cortez - Replica
I didn't get mine completely reinserted at first. The symptom I experienced when powering it back on is the power light comes on briefly and the bottom screen light flashes, then they both shut off. No flash from the upper display. Had to try reinserting 3 times before I had it in completely. I agree, DON'T REMOVE if you don't have to.
bfmackin - Replica
With the console still upside-down, open the DSi XL slightly. Push the lower display away from the upper case.
  • With the console still upside-down, open the DSi XL slightly.
  • Push the lower display away from the upper case.
  • Remove the lower display from the DSi XL.
Aggiungi Commento
Turn the DSi XL over and open the display. When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over. Use a pushpin to remove the four plastic screw covers on the front bezel.
  • Turn the DSi XL over and open the display.
  • When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over.
  • Use a pushpin to remove the four plastic screw covers on the front bezel.
Aggiungi Commento
Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
  • Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
Aggiungi Commento
Using two hands, gently slide the rear bezel upwards. The rear bezel will move only about 2 mm.
  • Using two hands, gently slide the rear bezel upwards.
  • The rear bezel will move only about 2 mm.
Aggiungi Commento
Insert a spudger into the gap between the front and rear bezel. Rotate the spudger away from the DSi XL, prying the two bezels apart.
  • Insert a spudger into the gap between the front and rear bezel.
  • Rotate the spudger away from the DSi XL, prying the two bezels apart.
Aggiungi Commento
In the same manner as described above, continue prying along the top edge of the front and rear bezels. In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
Aggiungi Commento
Separate the rear bezel from the front bezel.
  • Separate the rear bezel from the front bezel.
  • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
Aggiungi Commento
Using the flat end of a spudger, pry the rear camera off the rear bezel.
  • Using the flat end of a spudger, pry the rear camera off the rear bezel.
  • Remove the rear bezel.
Aggiungi Commento
Remove the Phillips screw holding the metal securing bracket in place. Lift the metal bracket off the camera.
  • Remove the Phillips screw holding the metal securing bracket in place.
  • Lift the metal bracket off the camera.
Aggiungi Commento
Use the tip of a spudger to lift the microphone from its seat on the front display bezel. Use the tip of a spudger to lift the microphone from its seat on the front display bezel.
  • Use the tip of a spudger to lift the microphone from its seat on the front display bezel.
Aggiungi Commento
De-route the microphone cable.
  • De-route the microphone cable.
Aggiungi Commento
Pull the microphone cable through the right hinge connecting the front bezel and upper case. Use the pointed end of a spudger to guide the connector at the end of the microphone cable through the hinge. To replace the microphone, use a pair of tweezers to guide the connector through the hinge.
  • Pull the microphone cable through the right hinge connecting the front bezel and upper case.
  • Use the pointed end of a spudger to guide the connector at the end of the microphone cable through the hinge.
  • To replace the microphone, use a pair of tweezers to guide the connector through the hinge.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
David Hodson
Membro da: 13/04/2010
128.686 Reputazione
158 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 7,380
