Introduzione
Use this guide to remove the plastic stylus housing from your DSi.
Unscrew the two Phillips screws securing the battery cover to the lower case. The screws remain captive to the battery cover.
  • Unscrew the two Phillips screws securing the battery cover to the lower case.
  • The screws remain captive to the battery cover.
  • Grasp the battery cover and lift out of the lower case.
Aggiungi Commento
Wedge the edge of a spudger in between the top of the battery and its lower case housing and pry upwards to dislodge the battery. Grasp the battery and remove it from the DSi.
  • Wedge the edge of a spudger in between the top of the battery and its lower case housing and pry upwards to dislodge the battery.
  • Grasp the battery and remove it from the DSi.
Aggiungi Commento
Two screws are hidden underneath two rubber feet highlighted in red. Use the tip of a spudger to pry the rubber feet out of the lower case.
  • Two screws are hidden underneath two rubber feet highlighted in red.
  • Use the tip of a spudger to pry the rubber feet out of the lower case.
One of the feet did break on me, tweezers came in handy for picking it out
Willie Narvaez - Replica
Remove the following screws securing the lower case to the body of the DSi:
  • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips screws.
    • One 2.7 mm Phillips screw.
Aggiungi Commento
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi. Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing. Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
  • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
  • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Aggiungi Commento
Carefully lift the lower casing from its bottom edge. The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
  • Carefully lift the lower casing from its bottom edge.
  • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
  • Pry the volume and SD board cable up from its socket on the motherboard with the flat edge of a screwdriver.
  • once the cable, highlighted in the orange box, is completely removed then you may take off the entire outer casing.
Aggiungi Commento
Pull the stylus straight out its housing and remove it from the rear case.
  • Pull the stylus straight out its housing and remove it from the rear case.
Aggiungi Commento
Remove the five 3.9 mm Phillips screws securing the stylus holder to the rear case.
  • Remove the five 3.9 mm Phillips screws securing the stylus holder to the rear case.
Aggiungi Commento
Lift and remove the left plastic protector from the DSi's rear case. Grasp the stylus holder from the left side and lift upwards to remove it from the DSi.
  • Lift and remove the left plastic protector from the DSi's rear case.
  • Grasp the stylus holder from the left side and lift upwards to remove it from the DSi.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 5,169
