Salta al contenuto principale
Nintendo DS Bottom LCD Screen Replacement
Cosa ti serve
  1. Nintendo DS Bottom LCD Screen Replacement, Battery: passo 1, immagine 1 di 3 Nintendo DS Bottom LCD Screen Replacement, Battery: passo 1, immagine 2 di 3 Nintendo DS Bottom LCD Screen Replacement, Battery: passo 1, immagine 3 di 3
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
    • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
  2. Nintendo DS Bottom LCD Screen Replacement: passo 2, immagine 1 di 1
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
  3. Nintendo DS Bottom LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the battery from the Nintendo DS.
  4. Nintendo DS Bottom LCD Screen Replacement, Back Panel: passo 4, immagine 1 di 1
    • Remove the seven 6.4mm Y00 screws located on the back.
    • If your DS has a lanyard attached to it, you can remove it to make the process of opening the top-left screw easier.
  5. Nintendo DS Bottom LCD Screen Replacement: passo 5, immagine 1 di 3 Nintendo DS Bottom LCD Screen Replacement: passo 5, immagine 2 di 3 Nintendo DS Bottom LCD Screen Replacement: passo 5, immagine 3 di 3
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
  6. Nintendo DS Bottom LCD Screen Replacement, Motherboard replacement.: passo 6, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Nintendo DS Bottom LCD Screen Replacement: passo 7, immagine 1 di 3 Nintendo DS Bottom LCD Screen Replacement: passo 7, immagine 2 di 3 Nintendo DS Bottom LCD Screen Replacement: passo 7, immagine 3 di 3
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
  8. Nintendo DS Bottom LCD Screen Replacement: passo 8, immagine 1 di 2 Nintendo DS Bottom LCD Screen Replacement: passo 8, immagine 2 di 2
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Nintendo DS Bottom LCD Screen Replacement: passo 9, immagine 1 di 2 Nintendo DS Bottom LCD Screen Replacement: passo 9, immagine 2 di 2
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Nintendo DS Bottom LCD Screen Replacement: passo 10, immagine 1 di 1
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
  11. Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: passo 11, immagine 1 di 2 Nintendo DS Bottom LCD Screen Replacement, Bottom LCD Screen: passo 11, immagine 2 di 2
    • Peel off the black cushion foam on the bottom touch screen to expose the ribbon cable.
    • Gently lift the screen out of the base.
Conclusione
Altre 22 persone hanno completato questa guida.
dnguye26
Membro da: 10/28/09
694 Reputazione
4 Guide realizzate
Cal Poly, Team 18-3, Maness Fall 2009 Membro di Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Membri
28 Guide realizzate
2 Commenti
I like it but add a step 12 maybe, to see how to put in a new screen.
Zackary Benton - Replica
Why was this unfinished guide published?
Or was it just mistitled?
"How to 'almost' remove the lower screen"
mgoerlich1990 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 277
Tutti i Tempi: 41,897
