Introduzione
This guide will show how to replace the Nintendo 64 motherboard.
Remove the expansion pack cover by pushing in the tab and pulling out.
  • Remove the expansion pack cover by pushing in the tab and pulling out.
Aggiungi Commento
Lever the expansion pack out using the metal spudger.
  • Lever the expansion pack out using the metal spudger.
  • A small spoon can be used in place of a spudger.
Aggiungi Commento
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Aggiungi Commento
Remove the two front feet of the N64.
  • Remove the two front feet of the N64.
Aggiungi Commento
Rotate to top side up and lift off top cover.
  • Rotate to top side up and lift off top cover.
Aggiungi Commento
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver. Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
I’m not entirely certain if it's a common difference, but my nintendo 64 doesn’t have fourteen screws, but rather, 8 screws, and instead of 3 heat sinks, it only has the one separate heat sink on the chip close to the memory expansion pack. additionally, aside from the 6 screws closest to the expansion pack, the two other screws are held on by nuts under the metal piece.
Avery Duncan - Replica
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the metal plate indicated in the example by sliding it back and then lifting it up. Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Aggiungi Commento
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Aggiungi Commento
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Aggiungi Commento
Remove the small metal bracket from the back of the expansion pack slot.
  • Remove the small metal bracket from the back of the expansion pack slot.
Aggiungi Commento
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger. Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
Aggiungi Commento
Remove the small metal bracket behind the expansion slot using the spudger. Remove the small metal bracket behind the expansion slot using the spudger.
  • Remove the small metal bracket behind the expansion slot using the spudger.
Aggiungi Commento
Remove the seven screws indicated in the example using the larger Phillips screwdriver. Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Aggiungi Commento
Lift off and remove the metal plate as indicated in the example.
  • Lift off and remove the metal plate as indicated in the example.
Aggiungi Commento
Remove the four screws indicated using the #1 Phillips screwdriver.
  • Remove the four screws indicated using the #1 Phillips screwdriver.
Aggiungi Commento
Lift up and remove the motherboard.
  • Lift up and remove the motherboard.
Aggiungi Commento
Conclusione
Altre 22 persone hanno completato questa guida.
tonymag28
Membro da: 28/10/2009
1.575 Reputazione
3 Guide realizzate
Cal Poly, Team 5-4, Regan Fall 2009 Membro di Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Membri
6 Guide realizzate
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 200
Tutti i Tempi: 42,754
