Salta al contenuto principale
Nintendo 64 Metal Plate Replacement
Cosa ti serve
  1. Nintendo 64 Metal Plate Replacement, Top Cover: passo 1, immagine 1 di 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Metal Plate Replacement: passo 2, immagine 1 di 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Metal Plate Replacement: passo 3, immagine 1 di 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Metal Plate Replacement: passo 4, immagine 1 di 1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Metal Plate Replacement: passo 5, immagine 1 di 1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Metal Plate Replacement, Metal Plate: passo 6, immagine 1 di 2 Nintendo 64 Metal Plate Replacement, Metal Plate: passo 6, immagine 2 di 2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Metal Plate Replacement: passo 7, immagine 1 di 2 Nintendo 64 Metal Plate Replacement: passo 7, immagine 2 di 2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Metal Plate Replacement: passo 8, immagine 1 di 1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Metal Plate Replacement: passo 9, immagine 1 di 1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Metal Plate Replacement: passo 10, immagine 1 di 1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Metal Plate Replacement: passo 11, immagine 1 di 2 Nintendo 64 Metal Plate Replacement: passo 11, immagine 2 di 2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Metal Plate Replacement: passo 12, immagine 1 di 2 Nintendo 64 Metal Plate Replacement: passo 12, immagine 2 di 2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Metal Plate Replacement: passo 13, immagine 1 di 2 Nintendo 64 Metal Plate Replacement: passo 13, immagine 2 di 2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Metal Plate Replacement: passo 14, immagine 1 di 1
    • Lift off and remove the metal plate as indicated in the example.
Conclusione
Altre 5 persone hanno completato questa guida.
LisaF818
Membro da: 11/29/09
143 Reputazione
1 Guida realizzata
Cal Poly, Team 5-4, Regan Fall 2009 Membro di Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 73
Tutti i Tempi: 11,333
