Introduzione
Voice recognition not working? Screaming at your Nintendo 3DS XL in hopes the game will finally pick up your voice? This guide will take you through the steps necessary to install a new microphone to have you back playing your favorite games in no time.
Cosa ti serve
Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
Hold the device so that the cover is facing up.
Using a plastic opening tool, pry off the cover starting at the top right corner.
Hold the edge of the cover to ensure it does not reattach.
Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
Take off the cover of the device and set it aside.
Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
Altre 4 persone hanno completato questa guida.
2 Commenti
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
please learn to repair the mic of new 3ds xl
