Introduzione
Is your 3DS not responding correctly to your Circle Pad inputs? Replace the bottom joystick mechanism and get moving again.
Cosa ti serve
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
Altre 11 persone hanno completato questa guida.
