Introduzione
The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
Parti
Nessuna parte richiesta.
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Aggiungi Commento
Remove lens mount from the camera.
  • Remove lens mount from the camera.
  • Be careful not to lose any of the three loose pieces that are under the lens mount.
Aggiungi Commento
Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
  • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
  • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
Aggiungi Commento
Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
Aggiungi Commento
Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all). Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all). Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
Aggiungi Commento
Remove the front case from the camera.
  • Remove the front case from the camera.
  • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
Aggiungi Commento
Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
Aggiungi Commento
Desolder the wires and remove them from the communication board.
  • Desolder the wires and remove them from the communication board.
  • Note: If you are unfamiliar with soldering techniques, click here for a guide.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Zachary Phillips
Membro da: 08/04/2011
178 Reputazione
5 Guide realizzate
Cal Poly, Team 25-26, Garner Spring 2011 Membro di Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,964
