Salta al contenuto principale
Nikon D70 Memory Compression Board Replacement
Cosa ti serve
  1. Nikon D70 Memory Compression Board Replacement, Battery: passo 1, immagine 1 di 1
    • Use your finger tip to pull the battery release tab toward the center of the D70.
    • Open the battery door and rotate it away from the bottom cover.
  2. Nikon D70 Memory Compression Board Replacement: passo 2, immagine 1 di 1
    • Pull the battery out of the D70.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon D70 Memory Compression Board Replacement, Bottom Cover: passo 3, immagine 1 di 1
    • Remove the following eight screws securing the bottom cover to the D70:
    • Six 5.8 mm Phillips screws
    • One 10.7 mm Phillips screws
    • One 8.2 mm Phillips screws
  4. Nikon D70 Memory Compression Board Replacement: passo 4, immagine 1 di 2 Nikon D70 Memory Compression Board Replacement: passo 4, immagine 2 di 2
    • Carefully pull the bottom cover to separate it from the body of the D70.
    • Remove the bottom cover from the D70.
  5. Nikon D70 Memory Compression Board Replacement, Memory Compression Board: passo 5, immagine 1 di 3 Nikon D70 Memory Compression Board Replacement, Memory Compression Board: passo 5, immagine 2 di 3 Nikon D70 Memory Compression Board Replacement, Memory Compression Board: passo 5, immagine 3 di 3
    • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
    • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
    • Be sure you are prying up the retaining flap, not the socket.
    • Pull the ribbon cable straight out of its socket.
  6. Nikon D70 Memory Compression Board Replacement: passo 6, immagine 1 di 1
    • Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
    • It is not necessary to completely remove this piece of tape.
  7. Nikon D70 Memory Compression Board Replacement: passo 7, immagine 1 di 3 Nikon D70 Memory Compression Board Replacement: passo 7, immagine 2 di 3 Nikon D70 Memory Compression Board Replacement: passo 7, immagine 3 di 3
    • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
    • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
    • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
  8. Nikon D70 Memory Compression Board Replacement: passo 8, immagine 1 di 1
    • Be sure not to lose the small iron core around the DC-In ribbon cable.
  9. Nikon D70 Memory Compression Board Replacement: passo 9, immagine 1 di 1
    • Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
  10. Nikon D70 Memory Compression Board Replacement: passo 10, immagine 1 di 1
    • Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
  11. Nikon D70 Memory Compression Board Replacement: passo 11, immagine 1 di 2 Nikon D70 Memory Compression Board Replacement: passo 11, immagine 2 di 2
    • Grab the memory compression board by its edges at the position shown in the first picture.
    • Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
Conclusione
Altre 4 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 23,757
