Introduzione
Use this guide to replace the CCD sensor board.
Use your finger tip to pull the battery release tab toward the center of the D70.
  • Use your finger tip to pull the battery release tab toward the center of the D70.
  • Open the battery door and rotate it away from the bottom cover.
Aggiungi Commento
Pull the battery out of the D70.
  • Pull the battery out of the D70.
  • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
Aggiungi Commento
Remove the following eight screws securing the bottom cover to the D70:
  • Remove the following eight screws securing the bottom cover to the D70:
    • Six 5.8 mm Phillips screws
    • One 10.7 mm Phillips screws
    • One 8.2 mm Phillips screws
Aggiungi Commento
Carefully pull the bottom cover to separate it from the body of the D70. Remove the bottom cover from the D70.
  • Carefully pull the bottom cover to separate it from the body of the D70.
  • Remove the bottom cover from the D70.
Aggiungi Commento
Remove the four ZIF ribbon cables highlighted in red by using the following procedure: Use your fingernail to flip up the ZIF cable retaining flap on each socket. Be sure you are prying up the retaining flap, not the socket.
  • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
    • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
    • Be sure you are prying up the retaining flap, not the socket.
    • Pull the ribbon cable straight out of its socket.
Aggiungi Commento
Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
  • Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
  • It is not necessary to completely remove this piece of tape.
Aggiungi Commento
Use your fingernails to carefully pull the ZIF cable lock away from its socket. Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop. Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
  • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
  • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
  • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
Aggiungi Commento
Be sure not to lose the small iron core around the DC-In ribbon cable.
  • Be sure not to lose the small iron core around the DC-In ribbon cable.
Aggiungi Commento
Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
  • Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
Aggiungi Commento
Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
  • Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
Aggiungi Commento
Grab the memory compression board by its edges at the position shown in the first picture. Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
  • Grab the memory compression board by its edges at the position shown in the first picture.
  • Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
Aggiungi Commento
De-route the two leads routed over the connector boxed in yellow. Use your thumbnails to push the connector out of its socket.
  • De-route the two leads routed over the connector boxed in yellow.
  • Use your thumbnails to push the connector out of its socket.
Aggiungi Commento
Remove the two Phillips screws securing the grip side of the rear cover to the D70.
  • Remove the two Phillips screws securing the grip side of the rear cover to the D70.
Aggiungi Commento
Remove the two Phillips screws securing the DC-In side of the rear cover to the D70.
  • Remove the two Phillips screws securing the DC-In side of the rear cover to the D70.
Aggiungi Commento
Carefully pull the sides of the rear cover away from the body of the D70. Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
  • Carefully pull the sides of the rear cover away from the body of the D70.
  • Pull the rear cover off the body of the D70, minding the LCD board ribbon cable that may get caught.
Aggiungi Commento
At this point, the capacitor is visible and its exposed contacts are boxed in red. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
  • At this point, the capacitor is visible and its exposed contacts are boxed in red. Even though they are recessed, be careful not to touch the contacts to avoid shocking yourself.
Aggiungi Commento
Peel back the piece of tape connecting the iron core around the CCD board ribbon cable to the inner case.
  • Peel back the piece of tape connecting the iron core around the CCD board ribbon cable to the inner case.
Aggiungi Commento
Remove the four 4.8 mm Phillips screws securing the CCD board to the D70.
  • Remove the four 4.8 mm Phillips screws securing the CCD board to the D70.
Aggiungi Commento
Remove the CCD board from the D70, minding any cables that may get caught. When reinstalling the CCD board, be sure to press the alignment posts on the right and bottom edges of the board up against the guides machined into the case while tightening the screws down.
  • Remove the CCD board from the D70, minding any cables that may get caught.
  • When reinstalling the CCD board, be sure to press the alignment posts on the right and bottom edges of the board up against the guides machined into the case while tightening the screws down.
Aggiungi Commento
Conclusione
Altre 21 persone hanno completato questa guida.
Great instructions.
One important note: When re-installing the CCD board ribbon cable into the CCD board, the cable will go into the connector about 2mm and feel like it's seated. However, the cable must go 3mm-4mm into the connector. Otherwise, you will get a "This Card Cannot Be Used" error message each time you depress the shutter button.
Ross Edmond - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 87
Tutti i Tempi: 28,290
