Introduzione
Visit our troubleshooting page for help with diagnosing your Nikon Coolpix S630. If the lens needs to be replaced, this guide will help you accomplish that. Gather all of the tools that are listed below before you begin.
The battery compartment is located on the bottom of the camera.
  • The battery compartment is located on the bottom of the camera.
  • Place your thumb on the battery door.
  • Slide the door away from the camera in the direction the arrow points to.
Aggiungi Commento
Slide the yellow tab towards the back of the camera.
  • Slide the yellow tab towards the back of the camera.
  • The battery should pop out.
  • Remove the battery.
Aggiungi Commento
Press the memory card down into the camera.
  • Press the memory card down into the camera.
  • The memory card should pop out.
  • Remove the memory card.
Aggiungi Commento
Unscrew the two 3.5mm Phillips screws from the side with the AV outlet. Unscrew the 3.5mm Phillips screw from the opposite side of the camera. Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
  • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
  • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
Aggiungi Commento
Carefully remove the back casing from the camera.
  • Carefully remove the back casing from the camera.
  • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
Aggiungi Commento
Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up. Gently pull the ribbon from the logic board with tweezers.
  • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
  • Gently pull the ribbon from the logic board with tweezers.
  • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
Aggiungi Commento
Remove the metal casing from the logic board.
  • Remove the metal casing from the logic board.
  • There are three ribbons that connect the lens to the logic board as shown.
  • Place the flat end of the spudger underneath one of the black flaps. Carefully lift the flap with the spudger and gently slide the ribbon out.
  • Repeat the above process to remove the remaining two ribbons.
Aggiungi Commento
Unscrew the four, 3.5mm Phillips screws that hold down the metal plate.
  • Unscrew the four, 3.5mm Phillips screws that hold down the metal plate.
Aggiungi Commento
Carefully lift the lens off of the front cover. Carefully lift the lens off of the front cover. Carefully lift the lens off of the front cover.
  • Carefully lift the lens off of the front cover.
Aggiungi Commento
Conclusione
Cal Poly, Team 8-56, Johann Spring 2013 Membro di Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,354
