Introduzione
You will need a #00 phillip's head screwdriver and a black spudger (or equivalent tool).
Parti
Nessuna parte richiesta.
Turn over camera to find 5 apparent screws.
  • Turn over camera to find 5 apparent screws.
Aggiungi Commento
Remove all 5 screws from the bottom of the camera and store them carefully.
  • Remove all 5 screws from the bottom of the camera and store them carefully.
Aggiungi Commento
Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
  • Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
Aggiungi Commento
Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
  • Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
Aggiungi Commento
Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
Aggiungi Commento
With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
  • With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Aggiungi Commento
Find the five screws on the metal plate and remove them. One of them is in a hole in the corner of the metal plate. Also remove the screw at the bottom of the camera. Carefully lift metal plate from the right side to reveal a ribbon connected to the motherboard.
  • Find the five screws on the metal plate and remove them. One of them is in a hole in the corner of the metal plate.
  • Also remove the screw at the bottom of the camera.
  • Carefully lift metal plate from the right side to reveal a ribbon connected to the motherboard.
Aggiungi Commento
Lift the white flap with the spudger to release the ribbon and remove back metal plate. Lift the white flap with the spudger to release the ribbon and remove back metal plate.
  • Lift the white flap with the spudger to release the ribbon and remove back metal plate.
Aggiungi Commento
Lift the two ribbons with the spudger to disconnect the lens and pull it out. Lift the two ribbons with the spudger to disconnect the lens and pull it out. Lift the two ribbons with the spudger to disconnect the lens and pull it out.
  • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
Aggiungi Commento
Conclusione
Ryan
Membro da: 12/04/2011
131 Reputazione
6 Guide realizzate
Cal Poly, Team 18-24, Garner Spring 2011 Membro di Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,015
