Parti
Nessuna parte richiesta.
Turn over camera to find 5 apparent screws.
  • Turn over camera to find 5 apparent screws.
Aggiungi Commento
Remove all 5 screws from the bottom of the camera and store them carefully.
  • Remove all 5 screws from the bottom of the camera and store them carefully.
Aggiungi Commento
Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
  • Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
Aggiungi Commento
Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
  • Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
Aggiungi Commento
Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
Aggiungi Commento
With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
  • With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Aggiungi Commento
On back of LCD screen, locate the three screws underneath the ribbon and remove them.
  • On back of LCD screen, locate the three screws underneath the ribbon and remove them.
Aggiungi Commento
Take out rectangular component on the side where the screws were. Pry apart screen from back casing using the spudger.
  • Take out rectangular component on the side where the screws were.
  • Pry apart screen from back casing using the spudger.
Aggiungi Commento
Conclusione
Ryan
Membro da: 12/04/2011
131 Reputazione
6 Guide realizzate
Cal Poly, Team 18-24, Garner Spring 2011 Membro di Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,025
