Salta al contenuto principale
Nikon Coolpix P90 Flash Bulb Replacement
Cosa ti serve
  1. Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: passo 1, immagine 1 di 3 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: passo 1, immagine 2 di 3 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: passo 1, immagine 3 di 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: passo 2, immagine 1 di 2 Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: passo 2, immagine 2 di 2
    • Press the button located on the top-right side of the camera's body to open the flash compartment.
  3. Nikon Coolpix P90 Flash Bulb Replacement: passo 3, immagine 1 di 1
    • Position camera as seen in the image here. This will make using the tools much easier.
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws from inside the flash compartment.
  4. Nikon Coolpix P90 Flash Bulb Replacement: passo 4, immagine 1 di 1
    • Place the Plastic Opening Tool along the crack on the side of the flash compartment cover.
    • Use this to pry open and detach the cover.
  5. Nikon Coolpix P90 Flash Bulb Replacement: passo 5, immagine 1 di 2 Nikon Coolpix P90 Flash Bulb Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #000 Precision Screwdriver, remove the 4.0 mm screw from the plastic cover.
    • Once the screw is removed, detach the plastic cover.
  6. Nikon Coolpix P90 Flash Bulb Replacement: passo 6, immagine 1 di 2 Nikon Coolpix P90 Flash Bulb Replacement: passo 6, immagine 2 di 2
    • Carefully remove the flash bulb holder with your fingers. (Use image as a reference.)
    • The flash bulb holder is the black, cylinder cartridge.
  7. Nikon Coolpix P90 Flash Bulb Replacement: passo 7, immagine 1 di 1
    • Using the end of the Plastic Opening Tool, pry the metal bulb frame out of the socket. (See image for reference.)
  8. Nikon Coolpix P90 Flash Bulb Replacement: passo 8, immagine 1 di 1
    • Once metal bulb frame is removed from the holder, remove the plastic stoppers on both sides of the metal flash bulb tray.
    • Use your fingers, both plastic stoppers should pop off with ease.
  9. Nikon Coolpix P90 Flash Bulb Replacement: passo 9, immagine 1 di 1
    • Using a Soldering Iron, desolder each of the wires connected to the light bulb.
    • Be careful! The soldering iron is hot. Do not burn yourself or the device. It should not be applied to the device too long to avoid damaging any of the device components.
    • For a comprehensive guide on desoldering, visit iFixit's Soldering and Desoldering Guide.
    • Give wires a few minutes to cool before reassembling the camera to avoid damage to any device components.
Conclusione
To reassemble your device, follow these instructions in reverse order. Make sure to give the soldered wires a few minutes to cool before reassembling the camera to avoid damage to any device components.
Cal Poly, Team 20-14, Maness Winter 2015 Membro di Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 805
